HomeSearchRegisterLog in
 problem pc
pau_kacang
PostSubject: problem pc   6th January 2010, 12:21 pm
sy nk tnye knp kite on pc msuk dh window tp balik asl mula..
pau_kacang
PostSubject: Re: problem pc   6th January 2010, 12:37 pm
sape2 th..leh x bg detail ckit nk slesaikan problem ni..huhuuh
LocoRoco
Moderator
PostSubject: Re: problem pc   6th January 2010, 1:13 pm
window die restrt mayb sbb file boot corrupt.. try fix window dulu..
repair window pakai recovery console :
--> lepas msk cd win > gi ke repair windw using recovery console n tekan 'R'
--> taip '1' (means we are working with C:\WINNT)
--> bile kuar prompt soh msk passwd, just enter je klu takde passwd
--> taip fixboot > enter (utk fix booting file n create new boot sector)
--> taip fixmbr > enter (utk fix master boot record yg damage mayb sbb virus)
-->restart
cara ini juga utk solve problems if ur pc prompt error spt ,missing NTLDR or NTDETECT
* try dulu nanti update blk results sini k
Very Happy
View user profile http://ppddunter.the-talk.net
jemi3886
PostSubject: Re: problem pc   6th January 2010, 8:14 pm
-->restart
Very Happy
gile power...huhu.. in addition, ade skit care2 nk troubleshoot memde alah ni..
1. Sebenarnye kite pelu tau ape yg berlaku yg menyebabknnye restart. simpton ni dipanggil Blue Screen Of Death (BSOD) Klik Sini Untuk Rujukan
Mcm care yg encik amer ni ckp, if error dia keluar UNMOUNTABLE_BOOT_VOLUME, so itu care dia. Cane nk tau pe error keluar?? Selepas on pc. tekan F8 sebelom windows loading, sebelom de page yg windows tgh gerak2 tu..
Sebelom page ni, tekan F8, Dia akan kuar mcm kt bwh ni...
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Disable automatic restart on system failure
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
2. Pilih yg disable automatic restart on system failure, then mugkin dia akan kuar page mcm kt bwh ni....
3. So skrg, kita dpt tau yg problemnye ialah, UNMOUNTABLE_BOOT_VOLUME, then gune care encik amer, use recovery console..
4. Kalo dpt error len, please post kt cni agar kite leh same2 menyelesaikan masalah tersebut..
5. Cubela..selamat beramal...huhu
Dari Abdullah bin 'Amr r.a., Rasulullah s.a.w. bersabda:
"Sampaikanlah PesanKu Biarpun Satu Ayat..."
Sucikanlah 4 hal dengan 4 perkara :
"Wajahmu dengan linangan air mata keinsafan,
Lidahmu basah dengan berzikir kepada Penciptamu,
Hatimu takut dan gementar kepada kehebatan Rabbmu,
..dan dosa-dosa yang silam di sulami dengan taubat kepada Dzat yang Memiliki mu."
LocoRoco
Moderator
PostSubject: Re: problem pc   6th January 2010, 8:32 pm
renung-renungkann....!! cheers
siti
PostSubject: Re: problem pc   10th January 2010, 11:41 am
cm ne plak kalu pc xlh msk windows.duk loading pah ceroh.
bru ni g format pc tu guna cd recovery.Lepas format msk window ok je tp bile shut down then turn on blk jd xlh msk windows,duk loading pah ceroh..dop tau mnde mslh..tlg eh sapa hok panda..buntu dh nk mikir mnde mslh.
jemi3886
PostSubject: Re: problem pc   15th January 2010, 3:28 pm
erm..kalu loading pah cheras tu, besenye windows je corrupt, tp mgkin jgak harddisk or ram problem.. try reformat pakai windows xp biasa,
nhaz
PostSubject: Re: problem pc   26th April 2010, 1:57 pm
kalau on pc, masuk password, sempat masuk window 2saat, tuptup automatic terus log off...camne ek nak resolve..? tolong...
View user profile http://einmall2u.blogspot.com
LocoRoco
Moderator
PostSubject: Re: problem pc   26th April 2010, 2:32 pm
could be 'spyware' Evil or Very Mad
try this..
run > 'regedit'
go to > HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit these two values in right pane:
Shell
Userinit
Change these two values to
Shell=explorer.exe
Userinit = x:\windows\system32\userinit.exe
Exit from Registry & Restart
update here the results after tested.. Wink
nhaz
PostSubject: Re: problem pc   27th April 2010, 10:23 am
1. masuk password admin
2. masuk window jap..
3. trs kuor "saving your setting.."
4. log off
5. kuar prompt untuk log on window semula..
ein dah try guna safe mode..sama jugak keadaannya amer..
pastu, bila nak shut down td, kuar mende ni plok..
jemi3886
PostSubject: Re: problem pc   28th April 2010, 9:16 pm
bagusnya review..
Baik, dalam masalah mcm ni, mmg de kes spyware la, die infect pada winlogon, setuju dgn en amer katakan disitu. Memandangkan dah xboleh nk login windows, jadi xboleh nk edit registry lg. untuk advanced user, sy sarankan gune Hiren Boot untuk remove spyware tersebut, boleh guna hijack this, or boleh guna combo fix. HBCD tu rasenya dah ade dlm image ebook.., atau cara yang lain, format sahaja la ubatnya... sekian..
PostSubject: Re: problem pc   Today at 5:45 am
problem pc
 :: Troubleshooting-
